Sporatic going into gear issues
Old Mar 25, 2009 | 03:49 PM
Kevin@MVP's Avatar
Former Sponsor
Default Sporatic going into gear issues
01 with 109k miles picked it up last week to auto-x. Sometimes the car doesn't go into gear and I have to put it in neutral and pump the clutch a few times then it will go back in.
Is this a common issue? I'm going to replace the clutch master cylinder and fluid, anyone have any other recommendations while I'm in there?
Car is completely stock (for now)
Old Mar 25, 2009 | 03:57 PM
ahrmike's Avatar
I think its time for the 00/01/02 cars to get their CMC changed. A lot of these have been popping up recently.
Check the fluid, it should be black. Check the CMC, theres going to be drips of brake fluid. This was pointed out to me at my first s2k g2g. Changed the cmc, flushed fluids and its great! Have you changed the trans fluid recently too? That could help your shifting.
Old Mar 25, 2009 | 04:25 PM
Kevin@MVP's Avatar
Former Sponsor
Bought the car two weeks ago, just saw it for the first time today.
Haven't really had time to mess around with it. Going to change the CMC, almost positive that's what the issue is.
Old Mar 26, 2009 | 09:32 AM
xeuxx's Avatar
Do the slave too....
For every pump they are both getting equal wear and tear. If one is on it's way out i'm sure the other is right behind it.
http://www.hondaautomotiveparts.com/
That Guy 1987
Jacksonville
Jan 3, 2013 02:56 AM
heffergm
Nov 20, 2008 05:19 PM
ken reich
Oct 17, 2004 08:40 PM
johninator
Apr 24, 2004 09:19 AM
David1
Nov 26, 2003 08:17 AM
