sprung a leak
Old Dec 4, 2021 | 02:21 PM
J’s Siverstone AP1's Avatar
Default sprung a leak
i had my car sitting for a few days and then after i moved it i noticed a rather decent size spot where fluid leaked out. i wiped my finger and smelled it and it was brown with a reddish hue. smelt kinda sweet but not much smell at all
i really dont think its oil (oil level is good, oil is also golden) and i really dont know what it is. its not differential fluid cause its underneath the back left corner of the engine bay, in that area.
the only thing i noticed when i drove my car was that it was very hard for me to get into reverse (i wasnt forcing it, and i went 2nd, 1st, reverse.)
does anyone have an idea of what fluid it could be? and where from? i jacked the car up and only fluid i saw was a small amount of fluid on the plastic panel behind the front left wheel
i really think it may be transmission fluid. where would the trans leak from if it was?
Old Dec 4, 2021 | 04:15 PM
noodels's Avatar
Put your tongue on it,will be sweet if coolant.
Ps spit it out
Old Dec 5, 2021 | 06:31 AM
Car Analogy's Avatar
Guessing a motor mount. They're fluid filled. A brown oily substance. When mount eventually tears, the stuff leaks out. Leaves a brown residue on mount.
Guessing the one on that side is torn.
That might also explain the difficulty shifting into gear.
Old Dec 5, 2021 | 07:06 PM
B serious's Avatar
Check which fluids are low
I'm guessing its brake fluid from the clutch system. Would explain your shifting issue. And the location of your leak.
Old Dec 7, 2021 | 09:38 AM
.Boston.'s Avatar
I second this. Most likely fluid from a engine mount. Mine were barely cracked and only leaked when I lifted one end of the car up.
samsam5886
Apr 24, 2009 11:04 PM
shiesty
Aug 26, 2006 01:55 PM
Blue_S2
May 18, 2006 12:05 PM
TougeBomber
Jun 25, 2005 06:39 PM
NFRs2000NYC
Oct 1, 2003 09:26 AM
