SRS light stays on
Old Jun 22, 2006 | 05:14 AM
XLeezardx's Avatar
Default SRS light stays on
After removing the hardwire kit for my valentine, my SRS light now stays on. Is this normal?
Old Jun 22, 2006 | 05:15 AM
Wisconsin S2k's Avatar
no, something was damaged or a wire was cut/damaged. you need to find and isolate the problem and correct it.
Old Jun 22, 2006 | 05:50 AM
XLeezardx's Avatar
Damn, now thats going to be a pain.
Old Jun 22, 2006 | 03:54 PM
gfacter's Avatar
The dealer can read the SRS code and tell you where the fault is coming from.
I had a SRS light on for 2 years (after I installed my 4 pt roll cage) I was able to get someone at the dealer read it for m recently.
I then found the fault (crimped wire on the passenger seat belt assy) and fixed it
Old Jun 22, 2006 | 03:56 PM
importkid's Avatar
first thing is first...check the fuse.
Old Jun 22, 2006 | 04:01 PM
C4SxM5's Avatar
theres a way to reset it manually if you search the forum, but if you don't know why its on then fix the problem before resetting it.
GL
Old Jun 22, 2006 | 08:19 PM
SenderGreen's Avatar
This is true.
There is also a way to check your SRS DTC to help isolate your problem without just reseting it first. There's a brief explanation near the bottom of the "ultimate check engine light" thread. Although the SRS is not the CEL, you can use the SCS method of retrieving your SRS DTC.
Shipley
Mar 9, 2009 02:08 PM
s2konroids
Oct 16, 2006 01:15 PM
Iwantas2k
May 16, 2004 11:12 AM
adcs2k
Apr 27, 2004 03:49 AM
KaCee
Jun 14, 2002 03:58 PM
