Starter clicks aftermarket security system
Old Aug 30, 2017 | 03:27 AM
AP1Chief's Avatar
Default Starter clicks aftermarket security system
So, got a buddies car with a aftermarket security system. Well I think it is, I'll get some pictures today if it. Anyways, we took out a bunch of extra wires that a msd window switch and nitrous system was hooked to, and removed battery while doing this, hooked battery back up, no start, the starter clicks and throws the shaft to the fly wheel, but no juice to spin.
I noticed two wires coming from behind the push button starter wire loom are cut and wired into this black box, with a million wires going everywhere. It's quite the nightmare.
Anyways, my thought is these wires are the main feed to the starter, And this security system is not allowing it to send amperage. Soooo tried looking for the other cut side of the wire in the loom, and can't find it..... I do have a manual, can anyone guide me to the right page or area to figure out how to wire this thing back to factory wiring.
Old Aug 30, 2017 | 08:42 AM
AP1Chief's Avatar
Got to step 5 on manual, hot wire the black/white starter solenoid wire, and same thing happens, just clicks, no turn over.... dead starter?
Old Aug 30, 2017 | 10:13 AM
jwzimm's Avatar
Dead battery? If the battery doesn't have enough juice the starter won't be able to turn the motor over.
Old Aug 30, 2017 | 11:34 AM
Saki GT's Avatar
Yeah... have you checked the battery charge? Tried a second battery?
Old Aug 30, 2017 | 03:53 PM
AP1Chief's Avatar
yep, actually had it hooked up to my car while running still just click.
Old Aug 31, 2017 | 03:28 AM
AP1Chief's Avatar
That's why I think it's the starter
Old Aug 31, 2017 | 05:34 PM
slalom44's Avatar
Top Answer: 1
If the solenoid is engaging and your battery is good it is likely your starter. Worn brushes could cause this, although so could a bad ground or a frozen engine.
crank
Jul 12, 2013 05:51 AM
geared
Aug 25, 2012 05:49 PM
liquidgsr
Dec 6, 2011 05:16 AM
REVZ TO9
Apr 2, 2006 09:21 PM
