Starting the Engine from the Cold
Old Feb 16, 2002 | 01:27 PM
S2000spoon's Avatar
Default Starting the Engine from the Cold
Does anyone have problems starting the car after a cold morning. I live in the east coast which the temp will drop downt to 10 degrees at night.
I step on the clutch, press the start button, without gassing, the engine will start and then stall...this usaully happens when it really cold out. Any advise will help
Thanks,
Mike
Old Feb 16, 2002 | 02:27 PM
xviper's Avatar
There have been a couple of threads on this already. Try searching for "testut" (user name). He had this problem a while ago, so did I but the problems are now gone. I'd search but I'm on my way out of the house. Basically, let the thing die and eventually it'll learn and compensate. Also, it would help if you held the start button for a second or two longer to get it past that stalling phase. There are other things that you can check too and these are discussed in those other threads. If you haven't any luck with finding them, I'll give it a go when I get back.
Old Feb 17, 2002 | 03:27 AM
jguerdat's Avatar
That would be THIS thread.
I've noted this problem but only when the weather warms significantly and the ECU apparently modifies itself for that situation. When the weather suddenly chills off, the first start attempt stalls. I LET it stall. The second and subsequent starts are fine since the ECU sees the stall and modifies its start sequence. Be sure to let it stall.
Others have reported that cold starts still fail which would seem to point to other causes (dirty air filter, etc.)...
Old Feb 18, 2002 | 06:37 AM
S2000spoon's Avatar
Thanks for the help guys, but it stalls every morning when its cold out side.
I'm a little concerned, I've have tried holding the start button down longer then normal, also tried
waiting for the beeping to go away before i start it and still stall...
Thanks again,
Mike
Old Feb 18, 2002 | 06:55 AM
jguerdat's Avatar
Sounds like a trip to the dealer. It should not start any harder than your typical Civic (other than a weak battery since compression is higher)...
Old Feb 18, 2002 | 07:00 AM
S2000spoon's Avatar
I have talked to my dealer and all they says is
I would have to leave the car there overnight....
Oh well, I gotta let them try it out...
Thanks guys,
Mike
Old Feb 18, 2002 | 11:58 AM
txst's Avatar
I have a friend who has the exact same problem with his Mercedes here in Texas. After thoroughly frustrating the techs at his dealer, they called Mercedes' Tech Line and was told to try burning regular (not super) gas. It worked - appaently it has something to do with the winter gas blends.
I would be a little worried about doing that in an engine with an 11:1 compression ratio though...
Old Feb 18, 2002 | 05:26 PM
xviper's Avatar
[QUOTE]Originally posted by S2000spoon
[B]I have talked to my dealer and all they says is
Old Feb 19, 2002 | 06:46 AM
S2000spoon's Avatar
First off, i would like to thank all you guys for your time and advice...
xviper,
I don't have a block heater..also i don't have a torque wrench to check the spark plugs...also never added additives to the motor.
This morning i still had the problem starting the car....
Dam i guess i gotta bring it to the dealer...
Mike..
gbjhch9
Aug 31, 2014 10:23 AM
jal3lee
Jan 20, 2007 07:46 AM
chowbj
Jan 17, 2007 09:35 AM
mytoesarecrazy
Dec 29, 2006 02:11 PM
DrStuff
Dec 6, 2002 07:03 AM
