STB Install
Old Feb 13, 2006 | 05:37 PM
J3ffro's Avatar
Default STB Install
I just picked up a used Whiteline STB (I know I know, doesn't do much if anything but the price was right so I figured what the hell) and want to put it on the car. Unfortunately, it didn't come with installation instructions, and this being my first STB I'm a little unclear.
Do I need to jack up the car completely, slightly (just enough to take tension off), or do I keep it sitting on the ground?
Sorry if this is the wrong forum, seemed most relevent.
Old Feb 13, 2006 | 05:42 PM
bobushka king's Avatar
i just took off the bolts put the baron and tightened those mothers back up. It should take you about 10 minutes to do.
Old Feb 13, 2006 | 05:43 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
4 bolts job.!!!
Old Feb 13, 2006 | 05:49 PM
S2kracka's Avatar
Jacking up the car is a good idea to uncompress the suspension.
Old Feb 13, 2006 | 05:52 PM
J3ffro's Avatar
That's the way I was leaning, just concerned with (showing suspension noobie colors here) possibly messing up the alignment if I allowed it to get too far out of place.
Old Feb 14, 2006 | 01:25 PM
ThatllHappen's Avatar
Is there really much of a difference between doing that and just unbolting and putting it on? Every car I have ever put a strut brace on I would just take the bolts off, put the brace on and reinstall the nuts.
Old Aug 7, 2006 | 03:50 PM
oOweEe's Avatar
Did u all use a torque wrench like the instructions say? or just "tightened those mothers"
if you dont use the suggested torque to tighten it, what are the risks or any long term effects?
Old Aug 7, 2006 | 04:10 PM
speedblind's Avatar
Just throw it on there. You can't/won't change the alignment, just as you won't change the alignmen by swapping wheels.
The only downside of going super tight on the tophat bolts is that you can break them off if you put too much pressure on them. They aren't meant to be tightenned to 200 ft.lb., so just snug them up and be done with it. Check again in a week or so to make sure nothing's come loose.
vstypicals
Sep 1, 2009 04:37 AM
OCMusicJunkie
Dec 13, 2006 08:39 AM
Aze85
Jan 16, 2005 06:16 PM
amongmany
Dec 4, 2003 08:44 PM
charlie
Feb 27, 2001 07:43 PM
