steering wheel horn question
I replaced my steering wheel with the fg-360. I had to disable srs (still have question on dash light), but upgraded to a four point harness. Anyway, as for the steering wheel, does anyone out there have this on thier s2k? If not maybe someone knows where the single wire (leading from the 2 connected to the horn buttons is supposed to go?) Mugen stuff is great ...but I'm going to kill thier instructions artist.
I'm assuming it's ground, but I get nothing. Any help?
According to the manual (Ref: 22-94). You should check for continuity between connector 2 (A) and the horn switch positive terminal (B). If you do not get continuity, check the cruise control set/resume switch. If the switch is OK you need to replace the cable reel switch. If there is continuity replace the horn switch.
Hope this helps.
Hope this helps.
Hmmmmm thanks! but this sucks. What exactly is a cable reel? There is a piece which is shaped like a donut, and has several wires sticking out of it. One which was cruise I am prtetty sure, and the other two srs. I removed this piece as I could'nt understand how the boss would fit with it on. This is driving me crazy! The srs light I should be able to fool, but this lack of horn!!! anyone read kanji? I can't imagine having to pull or lay wire on a Mugen kit.It seemed very complete minus a boss cover though..
