Stock FRP and high fuel pressure pump simple question
Hi
I am runnig a comptech supercharger with AC with tock injectors
I have a walbro 255 LPH@90 psi (Comptech is rated 255lph@43) and the stock FMU.
I have a question
the stock FMU is rated @ 43psi, if the fuel pump is sending fuel at @70spi, will the stock FMU decrease the pressure to 43 psi and return the rest of the fuel back. OR the fuel preassure will flow to the injectors at 70 psi
Thanks
I have a question
Thanks
The S2000 does have a fuel return line, that should answer your question. Also, knowing that with both SC setups that the FPR's only increase FP with boost should also answer your question. In all, your car will be fine if you were to run a high flow fuel pump with the stock FPR.
I guess I don't understand your question, I thought I did, but now I don't think I do. What do you really want to know, the exact fuel pressure increase that will be seen with just an upgraded fuel pump?
YES. that is it
YES
Will I see more fuel pressure than 43 psi with the stock FMU and 255LHP@90psi fuel pump
or I need an aftermarket FRP, Comptech FMU for example
Sorry If I have not expresed right my selft the first time, need to imporve my english capabilities
YES
Oh, I see what you're trying to do. I don't truly know your answer but from what I've gatherred, maintaining consistent fuel pressure (whatever the rate is) is best left up to a regulator, instead of the fuel pump. I'm sure someone else will chime in and have some first-hand experience with this.
Juan, the stock fuel pressure Regulator should work fine with the 550's. Don't use the Comptech FMU, It will just increase fuel pressure in boost Which you don't need anymore, now that you are using the 550's. The regulator controls the line pressure, not the pump. If you do decide that you need to adjust static fuel pressure, use a adjustable regulator, not a FMU.
FPR= Fuel pressure regulator Factory regulator is not adjustable. AEM makes a bolt on, adjustable regulator.
FMU= Fuel Management unit, Also known as a rising rate fuel pressure regulator. Comptech and Vortech supply one with there SC kits.
thanks Slows I thought that FMU was the same as FRP
since I cna t comunicate with the emanage, I changed the injectors back to stock and I ma installing the Comptech FMU because I need to move my car for the TV program I will not pass of 7000 rpm and will use some octane booster (up to 104 oct) and will keep the aftercooler
will let you know
will let you know
riceball777
09-21-2011 10:00 AM
