suspension squeaks!
Old Dec 25, 2009 | 09:16 PM
s2k_4life's Avatar
Default suspension squeaks!
okay so im not sure if this started happening before or after my clutch swap, but today i noticed that my front driver suspension is squeaking a lot. the noise doesn't resemble metal on metal sounds (worn brake pads) but metal to rubber (eeeeek eeeeek). so can you guys please help me out?
symptoms: going over rough pavements
turning the wheel even a little bit dry!!!!!=S
stopping (after is has been compressed: the rebound)
Old Dec 26, 2009 | 07:05 AM
s2k aok's Avatar
between the shock and spring there is a rubber pad, you'll wear it out eventually over time and there will be metal on metal, i get the noise going over bumps with my aftermarket rims but less with my ap1 rims...
mmm...vtec
Oct 19, 2009 05:43 AM
terrors75
Sep 30, 2008 05:17 PM
johnyboy32
Mar 19, 2007 12:42 PM
ryu_2k3
Oct 24, 2006 01:59 PM
cdelena
May 2, 2001 03:30 PM
