Sustained boost without engine code
Old Nov 19, 2003 | 10:48 AM
Eugeneo's Avatar
Default Sustained boost without engine code
Does anybody know how much boost can an S2 map sensor/computer handle before it goes into a engine code. Does anybody know if the honda ecu tables even have +map pressure calcs?
Old Nov 19, 2003 | 08:18 PM
KYS2000's Avatar
S2000 stock map sensor can read up to 10psi but ecu will throw a check engine light if it sees any positive pressure from the map sensor and it will also pull timing. If you go FI and without a stand alone ECU you will need something to clamp the map sensor voltage either electronically or mechnically. I had the missing link one way check value on my car but now I have the EMS system and am selling the one way check value.
Cody Strife
Jun 16, 2011 09:41 AM
MasterForce
Oct 7, 2010 04:34 AM
secrets2k
Mar 12, 2008 09:19 AM
hydeaway
Jul 31, 2005 02:13 PM
Mirror
Mar 22, 2005 06:24 AM
