Tapping after rebuild
Old May 4, 2014 | 01:25 PM
bobonacus's Avatar
Default Tapping after rebuild
Hi
I've done a major rebuild of my engine , it Ran fine on first start up then started to rattle on second start up and after
Engine has new pistons, crank checked and polished and shells gapped, cams and valve train replaced with newer but second hand cams and followers.
Re Checked tappets and they are fine
Swapped TCT for the original that was fine and back again for the one that came with the replacement cams and valve trains and makes the same noise with both.
Removed alternator belt just to make sure nothing there was causing the noise.
I appreciate it's near on impossible to diagnose from a video but if anyone has any ideas at all I'd be really grateful, here's the link to a 1 minute clip
http://youtu.be/VyfhRN_z7Fo
Cheers
Robert
Old May 4, 2014 | 04:52 PM
Slowcrash_101's Avatar
It sounds like rod knock, have you checked your clearances?
Old May 4, 2014 | 11:30 PM
bobonacus's Avatar
I used plasti gauge to check the new big end shells and all were in Hondas tolerance
Old May 5, 2014 | 06:45 AM
Did you re sleeve it or did u hone the cylinders?
Old May 5, 2014 | 01:45 PM
bobonacus's Avatar
Re sleeved and new over sized pistons
Old May 7, 2014 | 12:42 AM
bobonacus's Avatar
Checked compression and all cyls are 190psi (not that that actually indicates an awful lot!)
re-re checked valves, rotated engine several times to keep an eye on all the followers and all *look* ok
will a stethoscope help identify where it's coming from do you think?
Old May 7, 2014 | 03:37 PM
Car Analogy's Avatar
Yes. Stethescope. A real one. Not a ghetto socket extension or big screwdriver.
Thomas Guide
May 1, 2018 10:08 PM
Mooseman
Feb 20, 2018 09:32 AM
BoostedE21
Aug 15, 2016 12:40 PM
choleaoum
Mar 31, 2013 12:03 PM
luegos2k
Dec 18, 2008 09:24 PM
