TCT NEED HELPPP!
Old Feb 27, 2015 | 02:54 PM
S2k_razy's Avatar
Default TCT NEED HELPPP!
HELP!!!
I recently took my tct off to change the seals and only the big spring came out not the rest of the other little parts. Could it have dropped into the timing chain?? If so what would happen if you put it back together and cranked the engine??
Old Feb 27, 2015 | 03:05 PM
bendang2005's Avatar
Use a magnet to get the other parts out.
Old Feb 27, 2015 | 03:13 PM
S2k_razy's Avatar
I didn't know that at first and thought it would be fine to just put the tct with the big spring back on the engine. I've already cranked the engine with everything put together. The first time the car turned on and died instantly and now there's a loud rattling noise after the second crank. What problems could this cause??
Old Feb 27, 2015 | 04:17 PM
bgoetz's Avatar
What is the deal with this lately 2 in one week!
https://www.s2ki.com/s2000/topic/111...#entry23521962
Old Feb 27, 2015 | 04:48 PM
zeroptzero's Avatar
Can you tow it to Billman250's shop ?
Old Feb 28, 2015 | 10:16 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It is actually hard to loose the parts in the engine. Look around on the floor and on top of the subframe, they may have just fallen out.
Old Feb 28, 2015 | 10:18 AM
Billman250's Avatar
Top Answer: 1
Just cranking the engine without the tct properly installed will do major engine damage, especially things like bent valves.
westfield147
Apr 21, 2013 12:10 PM
deucesblack
Feb 9, 2013 11:01 AM
tugsta
Jan 7, 2012 07:24 AM
Jel
May 15, 2007 07:34 AM
