transmission lube pump
Old Dec 9, 2009 | 11:46 AM
keemaca's Avatar
Thumbs up transmission lube pump
whats up everyone i was wondering for those who do theyr own transmission and rear differential fluid change ...do you use the same pump for both or separate ones i want to do my diff. but im not sure if somehow it might effect using the same one if some how the fluids might mix a bit ..
Old Dec 9, 2009 | 11:48 AM
s2k dre's Avatar
Same pump will do just fine.
Old Dec 9, 2009 | 11:53 AM
drewmob's Avatar
same. the fluid drains out of the pump, just set it down in your oil drain pan for a minute until the majority of it seeps out.
Old Dec 9, 2009 | 12:42 PM
keemaca's Avatar
alright cool thanks...
Old Dec 9, 2009 | 02:11 PM
fatjoe10's Avatar
I thought the sulfur based rear diff fluid attacks transmissions and kills synchros... I'd just brake clean that stuff really good and make it dry before reusing it...
Old Dec 9, 2009 | 02:29 PM
zeroptzero's Avatar
I use seperate pumps for the fact that differential fluids contain compounds that are not good for transmission synchros. So I have one for the tranny and one for the diff. I'd rather not spend the time to clean each out after each use, so I have two pumps kept in plastic bags after they are used. With the small quantities used in the diff and tranny I'd rather not get any mixture of the fluids. It's probably a small point but I don't like the idea of mixing.
Old Dec 9, 2009 | 04:08 PM
MattZ28's Avatar
I just run the old transmission fluid through the pump and drain as much as possible out before pumping the new stuff in. Think about it, the internals of your tranny are coated with the old fluid so it won't hurt to rinse your pump out with it.
Old Dec 9, 2009 | 05:10 PM
zeroptzero's Avatar
yeah anything to get the few drops of diff. fluid out of the pump prior to pumping fluid into the tranny is good !
Old Dec 9, 2009 | 05:34 PM
Deception's Avatar
A little GL4 residue wont hurt the diff, so do the transmission first. Then pump the GL5 into the diff.
I just throw out the pump when done, they are only $5 at autozone. How many times a year do you change those fluids, once at the most.
Old Dec 10, 2009 | 02:39 AM
starchland's Avatar
I use the same for both. take a beer break between and let any fluid leak out. the amount of residual fluid will not hurt anything. why would you throw out a perfectly good pump?
dv55xc
May 16, 2013 08:21 PM
andy2000
Car Talk - Non S2000
Jul 29, 2011 08:33 AM
s2kayyyy
Sep 6, 2010 02:01 PM
9K-S2K
Oct 27, 2008 03:26 PM
tim62
Sep 24, 2007 07:14 PM
