Transmission problem
Old Jun 23, 2014 | 12:16 PM
cranked911's Avatar
Default Transmission problem
Hey guys, my car has been doing this weird thing lately. When I shift from 2nd to 3rd there is a weird "jolt" feeling I can feel on the gear shift. Its kinda hard to describe, I can feel the "gears" kinda grinding when I shift it into 3rd. You can also hear a slight "thuk" sound also. This happens like 15-20% of the time and is more prevalent when the car is cold. I was wondering what kind of problem this might be and if its something I should be concerned about. This only happens on 3rd gear. I try to double clutch to avoid this problem and it seems to be working but I dont want to double clutch every time I go into 3rd.
Car:
M.Y 2000, 175k miles rebuilt motor.
Old Jun 23, 2014 | 01:36 PM
stupkid's Avatar
Happened to me a few times. Changed the transmission fluid then it went away. Try that.
Sent from my SGH-M919 using Tapatalk
Old Jun 23, 2014 | 02:31 PM
s2kuae's Avatar
Same issue with mine. Changed the MTF to Honda but same issue.. Been double clutching for quite some time but not too much fun to drive. Be prepared to choose between rebuiling and getting a used tranny. I got a used AP2 tranny and it's much better to drive than the AP1. I got a ussed one coz rebuilding is far more expensive here and you can't buy only the synchros. You'll have to purchase the whole gear set! Aftermarket synchros also weren't available. Would have chosen rebuilding it, it just so happen that the store where I bought the tranny from doesn't know the difference between tha AP1 and AP2 tranny and got a really good deal for it.
Old Jun 23, 2014 | 06:05 PM
cranked911's Avatar
How much did the job cost total? and how did you decide when to swap out the trans?
Old Jun 24, 2014 | 06:44 AM
Car Analogy's Avatar
Double-clutch while cold. Once warmed up, drive normally.
If it gets worse, swap to used ap2 trans with the improved syncros.
Old Jun 24, 2014 | 09:22 AM
vtec9's Avatar
When you shift 2 to 3, don't move the lever in a straight diagonal line. Move it zig zag - up to neutral, right to be inline with 3, then up. See if that helps.
Old Jun 24, 2014 | 12:42 PM
cranked911's Avatar
Does anyone know roughly how much a swap would cost?
Old Jun 24, 2014 | 01:36 PM
s2klariat's Avatar
The infamous 2nd to 3rd gear "grind". Its not really a grind and is fairly normal in the Ap1. Try shifting at a slightly higher rpm. Around 4000-4500 or so.
brent_strong
Oct 4, 2009 12:36 PM
05Silverbeast
Jul 13, 2009 10:29 AM
nightcrawler7188
Jun 14, 2007 04:35 AM
weak_sauce
Mar 21, 2007 04:50 AM
enigmadsm
Jan 2, 2007 12:40 PM
