Transmission problems
Old Jul 22, 2001 | 01:38 PM
John N's Avatar
Default Transmission problems
If you have had the TSB for the 1-2 grind done (once, twice....) or a new transmission...and have had the problem return, would you please e-mail me privately? I need to back up my position with the problems that I have had, that they may/probably will reoccur??
Thanks,
John N
00 white/red
#462
Old Jul 22, 2001 | 03:42 PM
Utah S2K's Avatar
Most problems after the TSB has been performed (and on MY'01's) has been traced back to the cockpit. The S2000 shifts differently then a variety of other cars. I did here of one that continued to fail after the TSB was done and as I recall this was do to reidual damage done by the grinding which was not replaced when the TSB was done (i.e. worn gears as I recall). If it feels notchy, particullarly in the cold, you may want to switch to an aftermarket fluid (GL4). This has worked wonders for others.
Old Jul 22, 2001 | 05:21 PM
cdelena's Avatar
What are you talking about?! Did you just decide the TSB is the ultimate fix for this transmission or have you decided all cars are exactly the same as yours?
Let me tell you how mine and one other that I am very familiar with here in Texas work. Before the TSB it would grind on 1-2 shifts when the box got hot.. easy to reproduce on the first couple of shifts on a hot day after a high speed run on the highway. When the box is cool it works just fine.
After the TSB the symptoms are exactly the same.
Same driver when the box is cool or hot, except it only grinds when hot.
Come to Texas and trace some grinds back to the cockpit. I dare you!
SUis1
Nov 25, 2003 10:19 AM
StormBringer
Jul 16, 2002 09:34 AM
s800
Feb 4, 2002 02:01 PM
Mapman
May 18, 2001 06:38 AM
Kevin_in_Austin
Feb 26, 2001 03:54 PM
