Tuning of a VAFC
Old Feb 19, 2003 | 09:16 AM
KAMcDonald's Avatar
i think if you review previous posts, on a stock 00/01 car, you can get some HP increase. for 02/03, there will be less of an increase from VAFC, because Honda got a little more aggressive somewhere on the ECU. Pete ('02) and I ('00) showed different spark advance figures across the whole range. unsure of whether MAP ratios changed as well, but i think they did, just have no way of proving it.
some people like having the "kick" of vtec, i look at having it kick at transition as meaning i have missed power lower in the rpm range. previous posts have gone into changing vtec transition point lower to start getting the power from it sooner. too low and the engine is not ready for it and overall power will suffer. this is why you need to shell out the cash for some dyno time, you see what the a/f ratios are, where it can be safely changed and where the power is being developed.
as you start adding mods that make the engine breath better (I/H/E) or stock SC setup, VAFC lets you make sure you are getting better power while maintaing safe A/F ratios
for modded SC (smaller pulleys, larger injectors, etc) and turbo apps, i do not think the VAFC gives enough options, which is why i am trying out the emanage/e01 route.
keith
Old Feb 19, 2003 | 10:11 AM
SC-SUZUKA's Avatar
Alex, Yellow streak is running a Comptech SC.
Chris C.
Old Feb 19, 2003 | 10:33 AM
Yellow Streak's Avatar
Chris C.
What he said
-YS
Old Feb 19, 2003 | 11:05 AM
F1s2000's Avatar
Doesn't the comptech kit come with a piggy back box?
Old Feb 19, 2003 | 11:15 AM
KAMcDonald's Avatar
F1s2000, no. it does not.
comptech has an ESM, but that is only used to prevent ECU from seeing the boost. does nothing for A/F, ignition, etc.
it was designed to run on an otherwise stock motor.
keith
Old Feb 19, 2003 | 11:27 AM
Wisconsin S2k's Avatar
[QUOTE]Originally posted by gernby
[B]When searching, you should try both "VAFC" and "V-AFC".
My car is almost stock, and I found that I benefited by lowering my VTEC engagement point to 5600 or 5700 RPMs.
Old Feb 19, 2003 | 11:28 AM
F1s2000's Avatar
That sucks
Loves to Speed
Sep 15, 2008 01:47 PM
rikhemi
Jan 14, 2008 02:28 PM
SPLNDID
Dec 26, 2007 07:25 AM
Project
Apr 5, 2006 07:52 PM
Marcus_g
Mar 7, 2005 11:53 AM
