Turbo -> NA Checklist
Hey guys going to swap my car back to NA, is there checklist for the things you need?
So far:
ecu, injectors, exhaust manifold, exhaust, map sensor, o2 sensor, intake what else is there? Thanks.
So far:
It depends on your turbo setup. Most turbo setups take out the air pump, egr valve, have a different map sensor. Lots of setups you have to take out the vetc oil pressure switch. I now my pruning kit you have to take out the stock oil cooler/warmer. Coolent lines are often changed to cool the turbo. You probably have to plug the oil return in you pan or timing chain cover.
hmm what else is there.
Charper732
08-24-2017 05:37 AM
