update on drivetrain vib when cornering hard...
Well, I went on a long drive today (125 mile twisty road drive) and I can confirm
the vibration (if you want to call it that) is during hard RIGHT hand sweepers only.
No left turn, sweep, or any kind of left turn at all makes this vib. Leftys are smooth as butter.
If Im in a hard right corner or sweeper (40-50 mph for example) off the throttle, feels normal.
Then, whack the throttle wide open (i know.. not smart in a hard corner) and bam.. real vibration coming from the drivetrain.
Does this mean it is the differential for certain? Or could this be a wheel bearing?
Any replys are appreciated. Thanks.
What twohoos posted is for the inner CV's. I did this when my symptoms were like yours, mostly to try and see if it would solve the vibrations, but it did not help. It is quite possible this may work for you, but I am suspecting it is the outer CV's
It ended up being a useful diagnostic aid.
Either way, re-packing both the inner and outer CV's with a high quality grease is also good idea while you have it off.
It ended up being a useful diagnostic aid. Either way, re-packing both the inner and outer CV's with a high quality grease is also good idea while you have it off.
www.driveshaftshop.com
I just got new axels from them. I have the same prob. I will let you know if it is the fix.
Rich
Rich
saliv8
Jun 11, 2002 07:00 AM
