using the same oil filter
Originally Posted by DR. FEINSTONE,Aug 12 2008, 10:58 PM
This is going to be messy guys. Peace of mind, get a clean pan and loose the oil drain plug. Let all of the oil drains out and uncrew the oil filter to check for damage. You can reuse the motor oil. The alternative will cause massive of oils coming out all over, very messy to clean up. I thought dentistry is messy, but this is worse.
Don't do it!! Had the same thing happen to me which resulted in a small engine fire. The oil went everywhere. Some landed on the header under the heat plate, unfortunately i didn't see that. About 5 minutes after driving on the freeway I noticed smoke, pulled over popped the hood and wah-la a small fire on the headers.
Anyways, just go buy some new oil. Drain it, then take of the oil filter. And fill her back up.
Don't take the oil filter off with oil in the car!! Oil goes everywhere. Everywhere on the ground and everywhere in your engine compartment. !!
