V-AFC sputtering
Originally posted by sireousrex
Did your tuner make adjustments while the car was on the dyno? Or was he just guesstemating
Exactly why I ask. I have heard on more than a few occasions about people paying good money to a "tuner" who just does seat of pants adjustments.
Your problem comes from the fact that the ignition timing map is in a mis-match w/ your cams (VTEC on vs off).
To get a visual of this set the display to show you VTi and VTo. Now drive and get the car in the Dead Zone (where it sputters) and note the VTo = ON but the VTi = OFF. In this state the ECU thinks you're on the low cams and is using the appropriate ignition timing map for the low cam, problem is, the V-AFC has you on the Hi cam lobs!
There is a function to half a$$ address this issue called the V/T Unmt (VTEC Unmatch Fuel Correction, pg 33) but it's only half a Band-Aid at best, don
