Vafc ????
Just picked up a used VAFC w/ harness. My question is: The TPS sensor reading on the VAFC is 100% all the time. I was under the impression that it should read variable numbers in tune with the throttle pedal. I need to know what wire is the TPS wire on the harness so that the VAFC is not on WOT all the time.
I appreciate all your help.
I can corroborate that something is very wrong with your harness- on the sensor check the amount should vary from 0 to 100%, assuming you did the sensor calibration. Even without it, you should be close to that, certainly not stuck on 100% all the time.
Do you have the sensors set to 6/6 and the TPS set to "up?"
KYS2000
Jun 10, 2003 09:25 PM
