Vafc ????
Old Jul 5, 2002 | 12:44 PM
astig00's Avatar
Default Vafc ????
Just picked up a used VAFC w/ harness. My question is: The TPS sensor reading on the VAFC is 100% all the time. I was under the impression that it should read variable numbers in tune with the throttle pedal. I need to know what wire is the TPS wire on the harness so that the VAFC is not on WOT all the time.
I appreciate all your help.
Old Jul 7, 2002 | 11:16 PM
Kwando's Avatar
Sounds like you have the wrong wire. Mine is at 0% when at idle.
Old Jul 8, 2002 | 06:04 AM
astig00's Avatar
[QUOTE]Originally posted by Kwando
[B]Sounds like you have the wrong wire.
Old Jul 8, 2002 | 06:36 AM
marcucci's Avatar
I can corroborate that something is very wrong with your harness- on the sensor check the amount should vary from 0 to 100%, assuming you did the sensor calibration. Even without it, you should be close to that, certainly not stuck on 100% all the time.
Do you have the sensors set to 6/6 and the TPS set to "up?"
Old Jul 8, 2002 | 07:25 AM
astig00's Avatar
Thanks, Todd, I will check that this evening!
Old Jul 8, 2002 | 08:13 AM
marcucci's Avatar
No problem. Apex'i uses the same nomenclature Honda does, the Helm's manual makes quick work of reverse engineering the adapter.
Old Jul 9, 2002 | 09:48 AM
RWD_RCKT's Avatar
[QUOTE]Originally posted by astig00
[B]
Exactly!!!
Old Jul 9, 2002 | 12:04 PM
astig00's Avatar
I checked the the settings and they were correct. i think it is wired incorrectly. Thanks RWD, i'll be waiting eagerly
Old Jul 9, 2002 | 09:07 PM
RWD_RCKT's Avatar
[B]I checked the the settings and they were correct.
Aze85
Jan 28, 2007 04:09 PM
mxt_77
Jul 27, 2004 04:06 PM
VR WHAT
Mar 14, 2004 02:45 PM
KYS2000
Jun 10, 2003 09:25 PM
