Vafc2 question
Old Oct 18, 2007 | 11:56 AM
ridestrt's Avatar
Default Vafc2 question
Hey guys just had a quick question. Also before someone says to search I have been for hours trying to figure it out. I recently installed a used vafc2 using a boomslang harness. I intialized the unit and all the settings are set to zero. I have it set to 6in 6out and from what I can tell from the vafc setting library I have all the intial setup stuff done correctly. The car runs totally normal except for a SLIGHTLY lower then normal idle but it throws a CEL after a minute or two of driving. I reset the ecu and still getting the light after a short drive. Almost all of the info I've found so far in the library pertains the the original vafc, I was wondering if perhaps the initial settings for a vafc2 are different and that could be where it went wrong but I don't know if thats true at all. Thanks for the help!
Old Oct 18, 2007 | 03:42 PM
Slows2k's Avatar
Get the code 1st.
My best advice for VAFC and VAFCII users is to remove them and not deal with the CEL's they cause.
Old Oct 18, 2007 | 05:29 PM
ridestrt's Avatar
fixed it thanks guys
Old Oct 18, 2007 | 07:38 PM
nightcrawler7188's Avatar
when i had mine in without being tuned it threw a code for a knock sensor malfunction. i removed it and the code disppeared. i guess you have to get them tuned in order for them to not throw codes.
Old Oct 18, 2007 | 08:21 PM
animeS2K's Avatar
What would be the point of having one without getting it tuned?
Old Oct 18, 2007 | 08:37 PM
i never got around to getting it tuned lol. of course i planned to get it tuned. but i ended up wanting money for other mods so i just took it out.
Old Oct 19, 2007 | 05:14 AM
ridestrt's Avatar
Ya I'm getting it tuned this weekend. I was just getting it all installed and ready to go so when the time comes we can get right to business. Everythings working fine now except my speedo randomly stopped working. So I need to go check all the connections on my yellowbox in case I wiggled something loose while messing with the boomslang harness.
vtec4life57
Sep 11, 2010 05:52 PM
duff0000
Sep 18, 2004 04:45 PM
RT
Apr 14, 2003 11:34 PM
ConeKiller
Feb 12, 2003 02:07 PM
GDPzS2000
Dec 31, 2002 08:15 PM
