valve adjustment question
With the hood closed it is very quiet. Can't hear anything over the fans... but if I pull next to something on my rightlike another car I can hear a slight ticking. Maybe an exhaust valve or just injectors. Jus got to work and the car drove flawlessly but I never went over 5 k. Gonna wait until Wednesday to do it again because I'm off andwouldnt wanna rush this on Monday night. Thank you guys
Did you check the exhaust smoke issue when you arrived at your work ?, did that issue resolve itself ?
Best to re-adjust at 30K miles, at the latest 40K.
After the first adjustment, I ran 80K and had two exhaust valves bottomed out, no gap. Lucky they didn't burn. The valve seats wear on the exhaust side and close the gap quickly is my guess. Mine go out of spec as early as 30K with spirited driving. I've done a few adjustments now, the car has 197K.
Good Luck!
Good Luck!
Make a quality video (Iphone is better than you think, even if you have to borrow a buddies) and post to youtube, then link to here. Noise could be the TCT that you are still hearing.
Your car was totally cold (sat over night) before you adjusted or checked clearance correct?
Good Luck!
Good Luck!
My settings have held for the last 100k miles, all my customers have held for over 60k....will likely go 100k. Not even .001 adjustment needed. And I assure you I do my share of spirited driving.
ill post one up tonight. Im positive it isnt tct and pretty sure it isnt just injector noise.
Good Luck!
Good Luck!
When you do VA's is the exhaust side tight and intake side loose. Thats how mine was, i had to tighten intake side by .002 and loosen exhaust side by .001
One car in over 600 had to have ONE exhaust loosened from .009 to .010.
Yours most likely had a va done before, if you are reading them correctly.
