valve adjustment question
i dont it had a VA bc it didnt even have a mtf change. i only adjusted 4 valves on exhaust side bc a .010 didnt fit without some good force. Therefore there is no way i overtightened any when i did it. Im gonna get back in there on wednesday with more feelers. wat i will do is make sure a .009 fits really easy and that a .010 is kinda snug.
here is a video of how it sounds. Its hard to hear anything really maybe i need to use my t2i for another video. Also ignore my gf talking....
http://www.youtube.com/watch?v=TYntI1tdt_E
and here is one before the valve adjustment
http://www.youtube.com/watch?v=EmJWC...eature=related
Cold engine, like barely above room temp to the touch, at the block. If you're working the exhaust side, the little knuckles on the cam should point to 11 o'clock position or so. Intake side: 2 o'clock.
Is the smoke blue, white, or gray? Gray: too much fuel, ok to drive. White: antifreeze/water, watch your engine temp very close, ok for a short drive to a shop. Bluish smoke: oil, no good. Don't drive. Take out plugs, look at them. While they're out, take off serpentine belt, put a ratchet on the crank pulley and spin it clockwise (facing the car, transmission in neutral). It will have some resistance, but be close to you being able to turn pulley by hand, no weird noises.
As a distant theory, if you screwed up valve adjustment real real bad, and a valve got bent, in the process it damaged a valve guide that's now letting oil into combustion chamber. But that's really unlikely.
RolanTHUNDER
Apr 2, 2018 10:03 PM
