Valve noise after valve adjustment
Old 01-17-2016, 08:47 PM
kukudm's Avatar
Default Valve noise after valve adjustment
Hi, I need some help here. I just finish my first valve adjustment. However at normal operating temperature, the valve noise seem to be noisier than before. I have a sound clip below. I would really like your expert opinion here. Does it sound ok? Should I re-do the valve adjustment?
https://youtu.be/lOfrIKy6-JY
I also changed a new set of OEM spark plugs.
Thanks in advance!
Old 01-17-2016, 09:00 PM
windhund116's Avatar
Received 1,476 Likes on 992 Posts
Were the valves tight, prior to adjustment?
Old 01-17-2016, 09:10 PM
kukudm's Avatar
Yes, exhaust valves were all too tight. Intake side was ok, only needed to adjust on 2 of them.
Exhaust valves were set to Billman recommended 0.11. Intake side 0.09
Car is an 2007 AP2, 50700 miles
Old 01-17-2016, 10:23 PM
Extra noise maybe those valves, loosen to 0.011 inch. Right? Not 0.11 inch. My 2007 had tight exhaust valves, too. And one tight intake. None were loose.
I did exhaust at 0.011 inch. And intake to 0.010 inch. Made engine a bit noisier at idle. But, runs much better throughout RPM range.
Old 01-17-2016, 10:35 PM
kukudm's Avatar
Typo. Yes loosen to 0.011 inch. Just double checked the feeler gauge I pulled out.
So wind, does your engine sound similar to mine? Or did I mess up on the adjustment too much?
Old 01-17-2016, 10:52 PM
Soviet's Avatar
Sounds pretty normal IMHO.
Old 01-18-2016, 05:57 AM
How is the car running like? Mine noticeably smoothed out the acceleration from 5K to redline --- after the valve adjustment. Idles very nice at steady 900 RPM.
Old 01-18-2016, 06:32 AM
Slowcrash_101's Avatar
Sounds fine to me, it has that slight sewing machine noise. You should hear the valve train but just barely, rather it be a hair noisy than not noisy at all(too tight).
Old 01-18-2016, 08:18 AM
kukudm's Avatar
I haven't really get on it after the valve adjustment, and only had a short drive to warm up the car. Mostly staying below 5K RPM. So I couldn't feel to much of a difference than before. The idle was about the same, around 1K RPM.
I could hear the valvetrain very faintly even in the car, with windows/top up and no radio. Is this too much?
Old 01-18-2016, 01:38 PM
EOE
EOE's Avatar
Sounds okay to me
Quick Reply: Valve noise after valve adjustment
