Valvetrain noise
Old Oct 8, 2008 | 05:13 PM
S2K Sideways's Avatar
Default Valvetrain noise
I recently had my valves adjusted by an S2k mechanic and the car does feel better. Heres the thing that's worrying me:
When the car is idling, the valves are ticking louder than normal...but once you give it just a little gas the noise goes away and the engine sounds smooth. Could this be an oil pump or oil filter problem? ANY IDEAS? HELPPP
Old Oct 8, 2008 | 05:59 PM
daktruckie99's Avatar
If it goes away when you rev that sounds like TCT symptoms. Did Billman do the VA?
Old Oct 8, 2008 | 06:42 PM
yea billman did it about 2 months ago ... once i hit the gas a little the ticking goes away
Old Oct 8, 2008 | 07:05 PM
Sounds like your timing chain tensioner. The throttle blip gives the oil pressure enough tension to make the noise go away. I'm surprised Bill didn't pick up on the noise.
Oil level where it should be?
Old Oct 8, 2008 | 07:12 PM
yea . . . imma give him a call this week anyway just to see what he says
Old Oct 9, 2008 | 08:42 AM
jyeung528's Avatar
let us know...
Old Oct 9, 2008 | 10:57 AM
05TurboS2k's Avatar
sounds like TCT....mine went 2 times... take it out ... sandblast the worm gear, then pin it and re-install.
-G
Old Oct 9, 2008 | 02:09 PM
do you think that might be the reason why i feel like my car doesnt have the power it should? suppose it is the TCT , can that affect the power output?
PaulF
Oct 29, 2009 12:30 AM
GaryB
Jan 22, 2009 01:35 PM
GaryB
Jan 22, 2009 10:35 AM
007james
May 14, 2007 11:41 AM
Hickey322
Sep 23, 2003 03:46 PM
