VSA Brakes and CEL Issue
Old Sep 4, 2010 | 03:35 PM
HighwayStar's Avatar
Default VSA Brakes and CEL Issue
I tried searching but didn't find anything.
Here what happen I was driving on the highway to work and a lady turns into my lane cutting me off to the point i had to slam on my brakes so i wouldn't t-bone her. When i did this the VSA light, (!) Light, and CEL all came on at once.
I pull off the highway to get somewhere safe and stopped at a red light when the light turned green the car felt as if i was hitting the gas and the brakes at the same time. Pull over turn off the car to check the Brakes everything looks fine just the rear pads need to be changed. turn the car on all the lights turn off but the CEL and the car drove like normal. I tried slamming on the brakes again to see if it would happen again and nothing that car act like it never happen only the CEL light on.
Im gonna pull the code tonight when i get home but what do you think or know it could be? Do you think its a one time thing or something more?
Old Sep 4, 2010 | 08:39 PM
INTJ's Avatar
It may have gone into limphome mode because you exceeded the abs parameters. Did it stall?
Old Sep 4, 2010 | 09:09 PM
f23power's Avatar
p2138?
-a
Old Sep 4, 2010 | 11:28 PM
No i didnt stall but i did brake to a Stop from 70 mph when i slam on my brakes i push both the brake and the clutch down. and i will put the code in the morning its raining bad so i cant use my scanner yet
Old Sep 5, 2010 | 10:49 AM
ok this is crazy i hook up the scanner and it said there no code and the light cleared it self ?!
I guess im just gonna do some wishful thinking and hope it doesnt come back
Old Aug 23, 2012 | 06:24 AM
Guillen805's Avatar
same thing is happening to my 07 the CEL and VSA ! lights come on then i turn the car off and there gone and then somtimes just CEL is on idk whats wrong with it and it drives normal as far as i can tell
Old Aug 24, 2012 | 05:53 AM
TonysMI4's Avatar
Its the speend sensors. You slammed on the brakes from 70 mph. One or more of the wheels locked up while braking while others are still turning. The speend sensors noticed that happened like they are meant to do and they threw the 3 code light on. When you restart your car , 2 of the lights turned off and 1 stayed on because the system was watching for it to happen again to make sure it didnt do it on its own. After a few miles and turning off and back on your car , the system will reset its self and all the light will turn off like they did. There is nothing wrong with your car. Its doing what its made to do.
Now ... why it felt like you were pressing the gas and brake at the same time after this all happened.... Could be a few things..
1. car went into limp mode. Its a safety thing the car does after some crazy shi* happens.
2. 1 or more of your calipers pistons got stuck for a sec after beating on the brake so hard.
Im going to say its the 1st answer ( limp mode ) because it drove fine after a restart.
Calamari
Sep 15, 2010 03:26 AM
GTS Jeff
May 31, 2009 09:43 PM
GaryB
Apr 24, 2009 10:34 AM
Dembo
Dec 17, 2006 01:04 AM
darkfx
Dec 27, 2005 08:08 PM
