VSA & Traction Control Light Stay On
Old Apr 1, 2013 | 07:31 PM
DodgeViper01's Avatar
Default VSA & Traction Control Light Stay On
I have started my car a few times this week and noticed that the VSA Light & Traction Control Triangle Light stay illuminated. Sometimes turning the car on and off gets it to go away. Any suggestions? 50,000+ miles on a S2000 is uncharted territory for me. LOL! Thanking you guys in advance.
Old Apr 2, 2013 | 03:24 PM
Not one response? Someone has to have or had a similar problem.
Old Apr 2, 2013 | 04:29 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the VSA light remains on, there is a fault in the system and a code will be stored.
Old Apr 2, 2013 | 06:04 PM
Thanks as always Billman. I will have to have my local shop pull the code.
Old Apr 2, 2013 | 08:01 PM
El S2000's Avatar
^ I always respond to these because I believe the lights you were talking about mine was doing the same thing. restarting the car would make it go away but it would randomly come back. What it ended up being was low brake fluid, just low enough so at the right angle/braking the BRAKE light would flash causing those two indicators to light up.
So in short, check your brake fluid too just in case.. I know.. Random.
Old Apr 2, 2013 | 09:56 PM
That is so funny, the little things in these cars. I will check that in the AM. Thanks for the insight.
Old Apr 3, 2013 | 03:10 AM
Billman250's Avatar
Top Answer: 1
It may be possible to get the codes via the blink method.
Old Apr 3, 2013 | 08:51 AM
Please explain in greater detail.
Old Apr 3, 2013 | 09:53 AM
SlowTeg's Avatar
http://lmgtfy.com/?q=honda+code+blink+method
Old Apr 3, 2013 | 11:31 AM
S2k-2NV's Avatar
I had the same problem and comes to find out I was low on brake fluid. Topped it off and it went away
nichigo
May 8, 2019 03:55 PM
jaor.s2k
Jan 11, 2016 12:28 PM
phatcivic
Jun 19, 2015 08:11 PM
barrett4bama
Feb 9, 2011 11:26 AM
X Factor
Dec 23, 2003 07:20 PM
