VTEC controller on an 04?
Old Jan 11, 2004 | 07:12 AM
jmccain's Avatar
Default VTEC controller on an 04?
I was looking to install a vetc controller on my 04 s2000 i was wondering if they make one for the 04 or if the old one would work on the new engine. thanks for the info
Old Jan 11, 2004 | 12:36 PM
AusS2000's Avatar
I'm sure a V-AFC will work. It isn't S2k specific and it only needs to connect to the VTEC wire, MAP sensor, Rev signal and a few others. Not sure if the 04 ECU pin out is the same as previous models but I'd be surprised if it had changed.
Old Jan 12, 2004 | 09:15 AM
modifry's Avatar
Honorary Member
I've often wondered how (exactly) does the VAFC change the VTEC engagement point?
I can see how it would be easy to activate the VTEC solenoid at a different rpm (I've done that myslef, just experimenting), but what does it do to adjust the fuel? Does it change the MAP voltage to indicate higher manifold pressure so the ECM injects more fuel? Or does it modify the IAT or other inputs? If it messes with the MAP, how does it compensate on FI engines where the MAP voltage is already higher than the maximum the ECM will tolerate?
Anybody know for sure?
Old Jan 12, 2004 | 12:59 PM
AusS2000's Avatar
I'm not absolutely sure but I believe it uses the compensation setting on the MAP signal when you have changed VTEC engagement. You are correct that once the MAP signal is clamped there's not much it can do and that's why I don't recommend the VAFC for FI.
The way some people get around this is to increase the fuel pressure (easy with Comptech) and then use the VAFC to pull fuel. That way you are always working with lower MAP signals and the chance of hitting the clamp level at VTEC are lower.
Old Jan 12, 2004 | 02:03 PM
modifry's Avatar
Honorary Member
Thanks, that makes sense. I didn't think altering the IAT signal would account for enough fuel increase for VTEC operation, but maybe I'll check that and see.
When I get time (not likely) maybe I'll capture some injector duration data and see how much IAT and VTEC/no VTEC affect it.
Old Jan 12, 2004 | 03:14 PM
mikecl713's Avatar
i dont think itll be worth it
the new 04 ecu is really really maxed out
Middlers
Jul 11, 2005 09:59 AM
hondaboyS2000
Apr 18, 2005 07:35 PM
Rio S2K
Aug 13, 2004 02:05 PM
michaelg
Apr 8, 2004 09:28 AM
DB-350ZTRACK
Dec 17, 2003 01:49 AM
