Weak Fuses?
Old Nov 26, 2002 | 07:18 PM
vananron's Avatar
Default Weak Fuses?
I have tried to put some neon lights in my car for looks, and I have blown two fuses by doing so. I have spliced power from the defroster, and from the cigarette lighter, both fuses blew within 1 minute. In my wifes Celica, I have been able to splice 4 of the same lights off of the same power source. What is the problem? What can be done aside from splicing right from the battery?
Old Nov 26, 2002 | 08:24 PM
xviper's Avatar
Have you considered using one of the 3 empty power taps in the under dash fuse panel? There are 3 male spade connectors on one side of the fuse panel. 1 is hot with ignition, 1 is hot all the time, 1 is hot with the dash lights. I suggest you take the one that comes on with ignition. Make sure you still have an inline fuse after this tap. This power supply is not shared with anything else that's stock. I have my radar detector on this one as well as my gauges.
Old Nov 26, 2002 | 11:46 PM
vananron's Avatar
Hello, I will look for those and try that, thanks
Old Nov 27, 2002 | 12:19 AM
Sunder's Avatar
I gotta check this one out... Was looking for something like that before.
User 71524
Nov 8, 2025 08:06 PM
for_my_s2k
Jul 27, 2013 06:09 PM
Kdlopez01
May 5, 2009 09:57 PM
Spec_Ops2087
Mar 23, 2009 12:25 PM
dmw16
Jun 26, 2006 11:22 AM
