weird compression readings
Old Apr 30, 2013 | 03:16 PM
s2kneub's Avatar
Default weird compression readings
ok, short and sweet. i just did a compression test warm with closed throttle on my 2001 and the results came out as follows: 220, 235, 240, 240. within 10% or not, this freaked me out. i then redid the test open throttle and the numbers all hovered around 240. my question is why the discrepancy in the results yielded from cylinder 1?
Old Apr 30, 2013 | 03:29 PM
SouthDakotaS2K's Avatar
It's hard to say, besides you were doing the first test wrong. Either way the numbers are good. 10% of 220 is 22psi so you are ok.
Old Apr 30, 2013 | 03:35 PM
s2kneub's Avatar
alright, thanks
Old Apr 30, 2013 | 03:40 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
always:
throttle open
all plugs removed
warm engine, run within the last 1/2 hour
injectors disconnected
Old Apr 30, 2013 | 03:44 PM
s2kneub's Avatar
ok, that's how i did the second test except i removed the fuel pump fuse instead of dcing the injectors. still seems weird though that the first test showed almost a 10% drop on only one cylinder.
Old Apr 30, 2013 | 11:25 PM
Kmelthratter's Avatar
Could be worn rings, one might have a scratch in the cylinder wall, or a valve that was too tight. I wouldn't freak out about it, but you might want to do a leak down test.
GUTI007
Mar 13, 2017 06:22 PM
solitarycheese
May 16, 2014 05:36 AM
Aydon
Oct 22, 2013 03:07 AM
Importedpower
Nov 20, 2010 12:28 PM
Moddiction
Jun 20, 2008 08:53 AM
