what is hydrolock?
Old Jul 15, 2003 | 05:47 PM
s2khondaimport's Avatar
Default what is hydrolock?
i heard about the term "hydrolock" many times on this board, regarding CAI.
According to other post, hydrolock is caused by water, which gets into the intake...
So can someone describe what hydrolock is. A DEFINITION IS GOOD.
what is the cause, effect, and how do you prevent it?
thanks!
Old Jul 15, 2003 | 06:33 PM
sluallstar's Avatar
The cause of hydrolock is what you mentioned...water. But it must be enough water to impact combustion. Water is sucked in the intake by driving through high water. The effect isn't a good one. If you're lucky, damage may be repairable, but most of the time the engine is toast.
Old Jul 15, 2003 | 06:43 PM
foolio's Avatar
I was curious too, so I googled it.
http://www.pcafcr.org/techtips.htm#Prevent...944%20Hydrolock
"There is no place for the water to go when the piston tries to compress it." If the water won't compress, I guess something else has to give.
Old Jul 15, 2003 | 06:45 PM
sebrings2k's Avatar
its when you smoke too much HYDRO and LOCK yourself out of your car!
Old Jul 15, 2003 | 07:03 PM
Big Ben's Avatar
Question:
[QUOTE]what is hydrolock?
Old Jul 15, 2003 | 07:34 PM
jeffbrig's Avatar
Cause: Water (as stated above) getting into the engine
Effect: As the piston rises on the compression stroke, air in the cylinder compresses, but water cannot be compressed. If the volume of water ingested is enough, it prevents the piston from rising to the top of the cylinder. When the piston stops, the crank is still turning, the other pistons are still firing, and the connecting rod is still pushing the piston upwards. Something has to give. If you are lucky, the engine simply stalls. But if there's enough speed and momentum, something breaks.
For the nitty gritty details, in our 2L 4 cyl, each cylinder is only .5L in volume. 11:1 compression means that .5L is reduced by a factor of 11 as the piston rises on the compression stroke. If you do the math, you'll see that .045 L (45 mL, or about 1.5 ounces) of water in any one cylinder can be enough to hydrolock.
Prevention: Don't allow water to get through your intake and into the engine.
Old Jul 15, 2003 | 07:48 PM
Stratocaster's Avatar
It costs 5k if it happens to you. (Dealer cost of my new short block)
Old Jul 15, 2003 | 08:31 PM
jeffbrig-thanks for your in detail input...
dan_uk
Aug 12, 2010 01:36 PM
Sukeetoshyoo88
Apr 14, 2010 10:15 AM
nte11igence
Sep 18, 2007 08:29 PM
jwkim
Apr 17, 2003 06:10 PM
Wisconsin S2k
Sep 12, 2002 04:05 PM
