What is this part?
What is this part?
Hi guys, I've been messing a little with my car today, trying to fix an unstable idle (when warm) and realized I don't know what this part is. I could not find it on Honda parts diagram either.
Anyone can give a hint?
On the intake manifold there's this cap, under which some sort of regulator sits
slavic (03-11-2017)
slavic (03-11-2017)
Like previous user wrote, it's number 1 in this diagram https://www.hondapartsnow.com/parts-...fuel-pipe.html
Unless there is a fuel leak around I wouldn't touch it.
As a side note: after cleaning the MAP sensor hole, sensor itself and one side of the throttle body with some carb cleaner, and screwing the above-mentioned FPD screw all the way - the car seems to run much better and the unstable idle seems to be gone. I will update after a longer drive.
Oops, too late. Touched it already. I thought the screw was loose and tightened it. Now after reading some posts my natural question is - how tight should that screw be?
Moddiction
04-05-2011 04:21 PM
