where to tape oil temp gauge
Old 10-03-2006, 05:11 PM
imdarkrider's Avatar
Default where to tape oil temp gauge
I sooooo know i'm going to get reemed out on this one, but I looked in FAQ and other places and really didn't find anything. Found where to get oil pressure off the fact sender but where for pressure?
Old 10-03-2006, 07:45 PM
xviper's Avatar
This sentence makes no sense.
Old 10-03-2006, 09:07 PM
Banned
Jasonoff's Avatar
Think he meant to say
Found where to get oil pressure off the factory sender but where for heat?
I have my sensor through the oil pan bolt. Just drill a hole through it and epoxy the sensor in.
Old 10-04-2006, 04:19 AM
yea sorry I was watching the news and typing at the same time :-( I have an oil temp gauge. Just wanna know where I should go for that. I think I saw that the new defi gauge has like an oil filter adaptor and then you just go off that. Am I correct or are they all like this?
Old 10-04-2006, 07:56 AM
Banned
Jasonoff's Avatar
I believe they have a sandwich adapter.
I have heard it reads high due to the radiated block heat.
Old 10-04-2006, 10:47 AM
pepperoni's Avatar
If your oil temp gauge/sender is Autometer, or if your temp sender is 1/8 in. NPT, Summit Racing sells the weld-in bungs for like $10. Remove your oil pan, drill a hole and weld the bung in.
http://store.summitracing.com/partdetail.a...15&autoview=sku
Here's a few pictures from my race motor for refrence;
http://jellybeanracing.com/John/Civi.../gauge1391.JPG
http://jellybeanracing.com/John/Civi.../gauge1393.JPG
http://jellybeanracing.com/John/Civi.../gauge1400.JPG
http://jellybeanracing.com/John/Civi...s/bung1413.JPG
$.02
Old 10-04-2006, 11:10 AM
Anyone know of a spot without tapping ??? :-) I don't mind taking down the oil pan because my apartment has a heated garage but i'm lazy :-P
Old 10-04-2006, 11:23 AM
Banned
Jasonoff's Avatar
It's real easy to drill through the drain bolt.
Just buy a 2nd one and do that. The only down side is you need an open ended wrench for an oil change.
mnr vortx f20c
11-27-2012 08:47 AM
08s2000CRbackinblack
07-09-2011 09:41 AM
LukeS2K4EVA
06-09-2011 11:19 AM
S2k1807
01-08-2008 06:27 PM
Quick Reply: where to tape oil temp gauge
