whining diff...how long will it last?
Old Sep 26, 2008 | 09:44 PM
pli's Avatar
pli
diff is whining.. sorry..typo.
Old Sep 27, 2008 | 06:16 AM
Kdog24's Avatar
Originally Posted by JoeyBalls,Sep 26 2008, 08:10 AM
Don't all S2k Diffs whine?, mine has been whining since day 1, I am up to 81,000miles, and the last 12 have been boosted, just don't dump the clutch
That's what I thought because mine does it as well. I just learned to live with it, or until something breaks I guess.
Old Sep 27, 2008 | 06:19 AM
Green_IS_Gold's Avatar
generally you can hear diffs working in every car especially at freeway speeds.
if it sounds bad to you, definitely check the fluid. chances are everyone in this thread (including me) could use a diff fluid change.
unless you do a lot of tracking or driving hard, the diff probably has a good while left on it.
Old Sep 27, 2008 | 09:45 AM
srl311too's Avatar
When I changed my diff fluid with a synth oil I noticed it seemed to have a louder whine. Replaced the oil with LE607 and it went back to quiet. Try a thicker oil.
Old Sep 27, 2008 | 01:13 PM
s2k aok's Avatar
i have some lucas (thick as can be sh1t) mixed with my mobile 75w90 and there is no whine...
Old Sep 27, 2008 | 03:44 PM
S2KPUDDYDAD's Avatar
When you dumped the clutch you most likely loosened the pinion torque that is why it is whining. You can torque the pinion nut down some to reset the preload on the pinion bearings. Get a shop manual to see how to set preload or PM me for my number and I will walk you through the process.
Old Sep 27, 2008 | 04:11 PM
Originally Posted by CKit,Sep 25 2008, 10:31 PM
Could last days, could last months. The question is: do you feel lucky?
Well do ya punk....do ya feel lucky???? Love Dirty Harry
Here is why your rear whined then broke ckit, bad gear to gear contact due to an improperly shimmed pinion. This rear was factory shimmed this way it was not worked on by anyone else. The pinion was not broke but, did have a few marks on it from the damage
Here is what it should look like after a new set of gears and the right shim
Old Sep 27, 2008 | 11:46 PM
pli's Avatar
pli
so its still driveable if i drive like a granny right? i still need my baby to run for a good month before the snow comes down...i have to travel back and forth from my school dorm to home every weekend...before sending it in to puddymod
Old Sep 28, 2008 | 04:38 AM
PM me your number so I can give instruction on helping you keep the rear in working order. If you drive it as is you may blow it all together, you are taking a chance drive the car.
RedPhoenixS2K
Jan 19, 2014 05:25 AM
samsam5886
Apr 24, 2009 11:04 PM
Millenion LTD
Jul 3, 2008 11:36 AM
SilverDC2 AP1
Oct 2, 2006 03:21 PM
news2kroller
Apr 1, 2006 11:18 PM
