window wont roll down
i disconnected my battery so i could reset me ecu for my test pipe. now my passenger side window will not roll down. i try pressing driver and passenger window button and the window will not roll down. what did i mess up this time?
You misunderstood Huntsmcgee: there's a rocker switch across the front of the window switches in the driver's door. If it's turned off, neither the driver nor passenger window switch will work. Check this rocker switch first, before wasting time on fuses, etc.
If it's not the simplest thing, then check the fuses, etc.
I've done that before haha
