wires to connect for scan tool
Old Jun 30, 2010 | 08:34 AM
hypforlife32's Avatar
Default wires to connect for scan tool
i know this probably sounds like a dumb question but i dont konw where the two wires are that need to be connected to clear codes. my srs light is driving me up a wall. where are these wires?? thanks guys
Old Jun 30, 2010 | 08:42 AM
suzuka-blue-s2k's Avatar
Are you looking for the OBDII Port to plug a scan tool into man? If so its on the driver side under the dash. When your sitting in the car there is that panel that you can rest your right leg on, look right behind it, right above your carpet and you will see it. Its about even with your center console. I hope I descirbed that good enough, not sure how else to.
Old Jun 30, 2010 | 08:45 AM
thanks, but i found my obd plug underneath the passenger side dash...? am i missing something here?
Old Jun 30, 2010 | 08:49 AM
I know the OBD port is on the driver side. Go look right under your steering wheel on the black plastic peice, its the part that goes around your key hole, and goes under the steering wheel. There is a sticker that says where the OBD port is located. You might wanna go look really quick!
Old Jun 30, 2010 | 08:50 AM
haha i am going right now. ill take a picture if its not there lol.
spets's Avatar
The early years have it on the passenger side, then they switched it to the driver's side if I recall.
Old Jun 30, 2010 | 08:52 AM
^ Ohh maybe its just the 00-01 models. My 02 has it on the driver side.
Old Jun 30, 2010 | 08:55 AM
yeah, it is on my passenger side. 100 percent sure. when i plug in a scan tool, it says please connect mcs wire or something like that? where is this wire?
suzuka blue: yeah it must be cause of the 00-01.
Old Jun 30, 2010 | 08:57 AM
My bad man, I had no clue that 00-01's had it over there. I have no clue what wire it wants hooked up either. Hopefully someone else will come in here and know. Dang I learn something new on here almost every day!
Old Jun 30, 2010 | 09:02 AM
lol dont we all. i was going nuts for a second, i was like wtf is that on the passenger side. ha. yeah, hopefully someone chimes in. thanks for the help. you lean something new every day
BrockB
Jul 1, 2010 05:30 AM
Freshjive
Mar 3, 2010 11:21 AM
TimEdwards
Sep 10, 2008 02:32 PM
silverbullets2k
Jun 3, 2004 10:25 PM
viscreal2000
Feb 19, 2001 12:12 AM
