Fine Swirls
What causes fine swirl marks on the paint?
Here is my method of washing the car
-2 Wash Bucket method with Grit Guards in each 5 gallon bucket
-Sheepskin mitt
-Final rinse with no nozel
-Waffle weave drying towel
Applying Sealant and Wax
-Foam applicator
-Cookie monster buffing towels
I had 3 coats of Zaino Z2 and it didn't have much swirls, and applied some P21S and I didn't see much swirls. I just bought some Meguiars #16 and applied it several weeks ago. I applied thin coats and it cured very quickly. It was a pain in the butt to remove and I had to apply some pressure to get it all off. I am noticing much more swirl marks now.
I was required to use some pressure to remove the wax, would this have caused the fine swirl marks? I really have to look in the light or sun to see the swirl marks.
I just tried rubbing the bottom of a CD with the microfiber towels, and noticed with a lot of pressure, it would cause some fine swirls.
I don't think I am going to use the M16 anymore, only reason I got it was because of the durability, but I am going to stick with P21S for ease of application and removal.
What do you guys figure caused the swirls? I am going to purchase a PC 7424 with CSS Orange, white and black pads. Going to try Poorboy's SSR 2.5 and SSR 1. Then apply a couple coats of Zaino Z2 Pro and 2 coats of P21S. Do you guys think the SSR 2.5 and 1 will be good enough?
Thanks.
-Sheepskin mitt
-Foam applicator
Thanks.
Sounds like your microfiber. A lot of pressure applied will make fine scratches. This irked me as well after doing a full detail (PC and polish), but, I have learned to live with it. My car is 95% swirl free, and the the swirls on it, you have to look directly in the sun to see.
Using the PC, doesnt that take most of the clear coat off. I have an 06 s2k but Im a little skeptical to take the swirls off my car since I think the paint is in fairly good condition.
My peeps down here tell me not to buff it yet. Not till a couple more years and they tell me to use a polish instead of wax since was supposedly takes ur clear coat off. I always here its the other way around so i dont know...i give up!
Jmike
Jmike
Originally Posted by Faber,Apr 15 2008, 09:55 PM
100 microns is the typical thickness on S2000's. 2-3 microns are taken off when polishing.
i was actually signing on here to post the same thing: what am i doing wrong?
I just polished my car with the PC and it was swirl free. a few days later (and after rain) I washed the car and lo and behold..swirls! I also used a grit guard in each bucket and the sheepskin mitt and all that good stuff. however, i've never washed my sheepskin mitt because I don't know how. is this the problem?
