WTF, why am I causing "Holograms"
Old Apr 17, 2009 | 03:18 PM
slanguage's Avatar
MF towels wont cause "holograms", just scratches if they are dirty or pick up dirt. Yes you should wash them before using.
I agree a white pad isnt meant for applying glaze. A black or blue pad is best. Also when applying glaze with a PC use a low speed, say like 2 should be fine. I have done this with sealant and a black pad before and never had an issue.
After applying the glaze, give it a little bit to start hazing over. Buff gently with a MF towel, then flip it over to a dry clean part and wipe it again. If it takes a lot of elbow grease to get it off, you probably applied too much. Do this to one panel at a time.
If you wish, after you put a coat of glaze on the whole car, you can do a wipedown with some QD.
Hope this helps.
Old Apr 17, 2009 | 03:19 PM
slanguage's Avatar
Also, what glaze are you using?
Old Apr 19, 2009 | 04:26 PM
JoeyBalls's Avatar
3M Hand glaze
Old Apr 20, 2009 | 08:12 AM
Downgear's Avatar
Poor quality micro fibers can cause scratches. Technically holograms are caused from machines especially rotaries when the polish is not worked in to the fullest extent.
Old Apr 20, 2009 | 02:02 PM
slanguage's Avatar
I have never used 3M glaze before, but I have used Meguiars Glaze before. They are similiar if I remember correctly. Just use the aforementioned advice.
jkelley
Feb 22, 2016 04:19 AM
RedCelica
Feb 21, 2011 05:28 AM
lilgookiemonsta
Apr 28, 2009 03:42 PM
S2KAYYY
May 22, 2007 08:13 AM
mugenpower_s2k
Mar 18, 2007 04:36 PM
