South Florida Owners from South Florida
45,000 Service...need Advice
Old Oct 3, 2005 | 08:42 PM
JC_S2000's Avatar
Default 45,000 Service...need Advice
Old Oct 3, 2005 | 08:56 PM
JC_S2000's Avatar
Originally Posted by eviltwin,Oct 3 2005, 08:45 PM
i can do it for you... im a certified honda technician.
PM sent
Old Oct 4, 2005 | 03:50 PM
CoralDoc's Avatar
Under the severe service schedule, the following items should be performed at 45k miles:
Items to Replace
1. Coolant in MY 2000 cars with Type I coolant (not necessary with >MY 2001 that use Type II coolant)
2. Brake fluid
3. Engine oil and filter
4. Air cleaner
5. Differential oil
Inspections:
Brake pads, discs, hoses, master cylinder and calipers
Tire inflation pressure
Tie rod ends, steering gearbox and boots
Suspension components - bolts for tightness and ball joints
Driveshaft boots
Parking brake
Lubricate door hinges
Check fluid levels in transmission & washer
Cooling system hoses and connections
Exhaust system
Fuel lines
Lights
That's a lot of work, so if the dealer is willing to do all of it for $300, that's not a bad deal.
If you do it yourself, it should cost about $60 for the fluids including the coolant. Hopefully, you'd know what to look for with the inspections.
Old Oct 4, 2005 | 04:40 PM
eviltwin's Avatar
Originally Posted by DEIGER,Oct 4 2005, 01:31 PM
Knowing some dealers they will always find something and scare you into fixing or replacing it. Use caution on your choice of dealers.
you wont have to worry about being taken advantage of with me. i go through the troubles of explaing and showing parts, concerns,
or anything that might be an issue with the car with the owner. i like to educate my customers nad make them smarter. it makes me doing my job and them trusting me easier.
Old Oct 4, 2005 | 05:28 PM
JC_S2000's Avatar
thanks for the help guys, this forum really rocks!!!
Old Oct 5, 2005 | 04:49 AM
mav's Avatar
mav
Go to Rick Case Honda, ask for Eddie (SpoonS).
Old Oct 6, 2005 | 04:53 PM
JC_S2000's Avatar
RALPH, thanks so much you are da man brother!!!
This is what I got
Great service,
took his time
explain everything that needs to be done
Make recommendations on what needs to be done next
Real CHEAPPPPP!!!!!
I definetaly gonna go again to do the rest of my stuff, i saved a bunch on money by switching to Ralph
JC
Old Oct 6, 2005 | 06:38 PM
eviltwin's Avatar
thanks for the kind words jc... anything you need just give me a holler
CraigScho
Feb 21, 2015 12:53 PM
superazn
Oct 4, 2012 06:38 AM
soon2beS2Kn
Mar 20, 2007 05:54 PM
hapa
Jul 6, 2006 12:44 PM
tritium_pie
Jan 7, 2006 11:52 AM
