South Florida Owners from South Florida
Can this be handled under warrantee?
Old Apr 28, 2008 | 01:12 PM
GDM S2K's Avatar
No prob lemme know if you need any other help
Old Apr 29, 2008 | 07:04 AM
SpoonS's Avatar
Hey 9 out of 10 times I get a 1457 its as simple as a loose gas cap. But im sure you already checked that. Josh as far as goodwill honda requires a lot from a customer to assist ,especially lately i havent seen a 100% help in a while.
SpoonS's Avatar
Originally Posted by GDM S2K,Apr 28 2008, 08:49 AM
the main thing is going to be the out of warranty good will thing. if you have a relationship with a local dealer where you have a record of service they should good will it for you
hey what dealer are you working at ?
Old Apr 29, 2008 | 09:22 AM
CoralDoc's Avatar
This is all moot now. After compiling all of the helpful information in this thread, I set aside a couple of hours this morning to troubleshoot. When I started the car to back it onto some ramps, the Check Engine light was no longer illuminated. Just because I was there and interested in what I might find, I removed, insepected and replaced the 2p connector for the EVAP bypass solenoid valve. There was no sign of corrosion. The Check Engine light is still out after two driving cycles, so I guess it fixed itself .
Code 1457 is not a loose gas cap, the correct code for that is 1456. When the CE light came on the first thing I did was to remove and replace the gas cap. The car went through about 10 driving cycles without having the light turn off, so I cannot guess as to why it came on in the first place, and why it went off.
Old Apr 29, 2008 | 10:15 AM
KeithD's Avatar
Sounds like your solution was very similar to mine. When this happend to me the dealership said it wasn't something important and it didn't impact the performance of the car.
Old Apr 29, 2008 | 10:37 AM
MX5RACER's Avatar
Sometimes it takes that many ignition cycles to test all the OBD functions. Some are tested everytime the ignition is cycled, some only tested X cycles of the ignition. I would clear the code, if you have not yet. Then wait and see if the code returns. I know that the Integras have an issue with the EVAP solenoid, at least the GS-R's do. The function of the EVAP system is to collect the gaseous form of gasoline, and not vent it to the atmosphere. Sometimes the charchol canisters get blasted with fuel vapor and get overloaded. Usually happens when there are drastic temperature changes. Like a 70 degree morning followed by a 90 degree mid-day.
Anyway, Josh, when you find that guy with the scanner, let me know... he owes me money!
Old Apr 29, 2008 | 12:45 PM
S2KSuzuka's Avatar
Josh,
do you still need the use of a scanner?
I have one, and it will reset the ecu log.
Mitch
and I don't owe mx5racer any money....lol
Old Apr 29, 2008 | 03:08 PM
CoralDoc's Avatar
So, even though the CEL is no longer on, the code is stored in the ECU? Is there any reason why I should clear it out?
MX5racer is just goofing around about the scanner. I was planning to have him come over to help with the diagnostics. And by "help" I mean that he would do the work and I'd try not to get in the way too much.
Old Apr 29, 2008 | 03:21 PM
GDM S2K's Avatar
MX5racer is just goofing around about the scanner. I was planning to have him come over to help with the diagnostics. And by "help" I mean that he would so the work and I'd try not to get in the way too much.
im pretty sure its stored in the ECU.
JackS
Jul 4, 2009 05:34 AM
ge2
Car Talk - Non S2000
Mar 11, 2007 05:05 AM
swells65
Nov 4, 2003 10:54 PM
Squeezer
Sep 25, 2002 07:54 AM
