Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
ring type rattle from engine/transmission area
Old 12-20-2002, 02:42 PM
~69erGi/Vo~'s Avatar
Default ring type rattle from engine/transmission area
I was wondering if anyone has experenced this: when going full throttle, there is a high pitch rattle (almost like the sound a ring would make sliding down a metal poll) coming from the transmission area of the car starting at vtec to redline? could it be the clutch plate TSB? also, what causes abnormally load clicking from the engine wile idle?
Old 12-20-2002, 02:52 PM
Matthews's Avatar
I have that problem too......I think is from the tranny
Old 12-20-2002, 03:57 PM
1badride's Avatar
Hehehe... heat shield - welding mine tomorrow.
I thought it was the tranny too... it probably isn't.
Old 12-20-2002, 04:07 PM
but if its the heat shield then why is it only resonating at full throttle/high rpm?
Old 12-20-2002, 04:44 PM
QIKSILVR's Avatar
That's what resonation usually does.. only at certain rpms.
Old 12-20-2002, 04:49 PM
hmm... but i had the heat shield check before... it was on tight
Old 12-20-2002, 05:18 PM
Matthews's Avatar
my is only at 3rd around 4 to 5k.....
Old 12-20-2002, 05:21 PM
mines in all gears at high rpm
Old 12-20-2002, 06:13 PM
boiler's Avatar
Take a look at this: https://www.s2ki.com/forums/showthread.php?...&threadid=41390
This will usually stop the ringing from the shifter. You can hold the shifter and move it slightly to see if it stops the noise, first.
This will also make the shifts smoother and easier.
Good luck,
Bob
sleepysnake
05-20-2016 12:20 AM
rocsix
01-20-2010 01:11 PM
Schreck
06-02-2008 03:39 PM
wangdoom
08-05-2005 01:23 PM
gosixers215
01-14-2005 01:03 PM
Quick Reply: ring type rattle from engine/transmission area
