Anyone know how to get a diff apart?
Old 08-19-2017, 01:53 AM
Nottm_S2's Avatar
Default Anyone know how to get a diff apart?
i took my diff off and swapped a new un in
how do i get the old one apart? I took all the bolts out and the casing is now loose but it wont come apart as far as i can see
the drive outputs are on and the prop drive is on with a mega tight bolt
Old 08-19-2017, 03:00 AM
unclefester's Avatar
https://robrobinette.com/S2000Differential.htm
Have a look at that
Old 08-19-2017, 10:52 AM
Nottm_S2's Avatar
the pics helped Fest, tah
i popped a couple of bolts through the holes in the driveshaft flanges and pressed em off from a flat pry over the casing (which i thought might crack)
i cant see the damage but even with those off it's stiff as hell, i'll take it more to bits later
Old 08-19-2017, 12:51 PM
E4RTH WORM JIM's Avatar
Is the diff fooked?
Old 08-19-2017, 12:59 PM
Nottm_S2's Avatar
Originally Posted by E4RTH WORM JIM
Is the diff fooked?
In short yup
https://youtu.be/zIiThz03dFE
It doesnt even rotate freely. A lot of resistance at certain points, for me that said fooked cog but i havent seen that yet
Old 08-24-2017, 02:56 AM
Nottm_S2's Avatar
I cant see the issue looking at it case off..
It rotates ok briefly then hits resistance going very tight (only just turnable by hand) before going free again
that would suggest the little gear at the front is fooked but to my non expert eye it doesnt look it. I'd expect a bearing to just be rough all the way round but wtf do i know?
These guys propose a reason for failure which looks reasonable
https://neatgearboxes.wordpress.com/2013/04/19/s2000-diffs-why-they-break-and-how-to-stop-it-from-happening-again/
Old 08-27-2017, 01:27 PM
surfer_crx's Avatar
You have to take the nut from the pinion shaft and tap the flange off in order to separate the case.
Old 08-27-2017, 10:54 PM
Nottm_S2's Avatar
i got the back off.. i cant get that nut off would have to make something to bolt to the prop flange i guess. Dont have a big vice or anything
Old 08-28-2017, 03:45 AM
What you trying to do to it?
Old 08-28-2017, 09:59 AM
surfer_crx's Avatar
Windy gun will sort it but they are are a cunt to torque back up and get right.
Quick Reply: Anyone know how to get a diff apart?
