Best N/A mods
#31
I've been told calculated flywheel horsepower changes per gear used as well. Higher losses in lower gears means bigger correction factor and higher apparent fly figures.
#32
Member
Uh-oh, dyno debate
A decent dyno will calc losses on coast down, so it factors whatever gear you are in.
My 310 bhp was on a hub dyno but that's atf, think it was 270 ish at the wheels.
#33
Mine started off as 231bhp and 151ft lbs as per Chris's EFI dyno peak figures.
Added:-
AEM V2 intake.
AEM EMS2 ECU.
Tegiwa/Js replica manifold.
Invidia N1 unresonated test pipe.
Milltek 70mm single exit exhaust.
Went back to the same dyno and remapped there. She made 244.1bhp and 157ft lbs torque peak figures Not to mention 20bhp gain mid range along with similar torque figures.
Added:-
AEM V2 intake.
AEM EMS2 ECU.
#34
Mine came in @ 225 whp and 165 lb/ft on a Dynapack hub dyno with 2.2L Spoon block, AEM V3 intake and cheap exhaust (now back to OEM), mapped on AEM series 2. Graph below shows the gains over a completely stock S2000 they had in earlier, it's surprising how much you gain from the extra capacity - low RPM torque is very nice now too.
Probably still cheaper to get a SC/turbo kit though...
#35
Black Knight
04-08-2009 09:17 PM
dhess
07-01-2002 03:30 AM
