CEL :(
Old Apr 24, 2008 | 02:43 AM
  #81
mugen888's Avatar
I have to go to him he said enfield is a bit far
Old May 4, 2008 | 09:30 AM
  #82
mugen888's Avatar
Ok heres the story up to date I have changed the injectors over today from 1 over to 4 but im still getting the same error code with the mugen ECU
When tango man tested my ecu it was literally minutes I guess i will need someone to run it in
misfire cylinder 4
Old May 6, 2008 | 12:06 AM
  #83
mugen888's Avatar
I'm at the dealers right now they cant seem to communicate with the mugen ECU
so I guess they cannot diagnose my problem.
I'm stuck now
has anyone got any suggestions
Old May 6, 2008 | 01:20 AM
  #84
MB's Avatar
MB
Member
It's prob not OBDii then.
Shame you couldn't have tested the Mugen for longer in the Tango mobile
Remind me, what issues do you have when you use the OEM ecu in your car?
Old May 6, 2008 | 04:09 AM
  #85
mugen888's Avatar
Managed to read the codes the flashing CEL is misfire in any cylinder then solid is misfire cylinder 4
Several things it can be according to the technician:
fuel pressure
tapet valve clearance adjustment *last done in 2006*
fuel filter may need changing
possibly map sensor
the technician has requested to take my car in for a few days for further diagnostics which will need to be rebooked as there are not courtesy cars available
OEM was giving a Air Control Valve Circuit Low Voltage P0412
I asked the technician why i was getting different errors with 2 different ECUs he said the aftermarket one required more resources to run
Old May 6, 2008 | 04:12 AM
  #86
MB's Avatar
MB
Member
Oh dear - watch those costs. They have you by the balls when they don't define a time frame or price.
Hence I learned my own engine management stuff.
Requires more resources? He must mean the Mugen uses a few less things than the OEM.
If it's a general misfire then the items in my signature are a good bet.
Can you swap a MAP with someone?
Fuel fitler is unlikely.
Clearances are quite likely.
Old May 6, 2008 | 04:19 AM
  #87
mugen888's Avatar
Yes well I have a spare map sensor i will bring along with me next time
fuel pressure will need to be checked
they will check clearences next time
yes I hope they dont chop my balls off with this I dont need a big bill at this moment in time
Old May 20, 2008 | 10:20 AM
  #88
mugen888's Avatar
I can finally say it's sorted
What a relief
Problem was valve clearances it was 2 years ago when it was last done so i guess its out of alignment.
The mugen ECU must be pretty picky with it
BIG thanks to ESEM who has helped me with diagnostics
SoSiiK
Oct 19, 2012 04:22 PM
c32b
Mar 16, 2012 09:25 AM
TigerStyle
Feb 9, 2011 05:09 AM
macr88
Engine
Jan 21, 2010 11:04 AM
Icemn2003
Feb 8, 2004 04:06 PM
