Cross threading fun
Old Jul 18, 2011 | 05:11 AM
Dembo's Avatar
Default Cross threading fun
I changed a fuel injector again yesterday, and one of the three nuts that holds on the fuel rail was a bit cross threaded. However in my haste, and taking it on and off several times, I've now ended up with 2 of the 3 nuts a bit crossed, to the extent that I can neither tighten them up fully, or get them off.
So what's to be done? Is this a job for a nut splitter, or is there some other trick? (I'm not talking about a rounded off or rusted bolt).
Old Jul 18, 2011 | 05:47 AM
lower's Avatar
I'm not familiar with the location of the injectors so this may be a stupid suggestion, but have you got the option of applying some heat to the nut to expand it? I've had success with that in the past
Old Jul 18, 2011 | 06:26 AM
loftust's Avatar
If you do try some heat, take care with your selection of heat source
A nut cracker should work; I'd then stick a thread chaser on the stud to ensure the thread pattern is OK for the new nuts
Old Jul 18, 2011 | 07:41 AM
razzele's Avatar
I ve just finished fitting some injectors today, dont drop anything under the IM !
Old Jul 18, 2011 | 08:54 AM
MB's Avatar
MB
Member
I guess you did, Raz?
I've lost 2 bolts down there!
Old Jul 18, 2011 | 08:57 AM
MB's Avatar
MB
Member
Dave, is the nut stuck on?
Are the threads on the bolt or the nut shagged?
Old Jul 18, 2011 | 09:09 AM
Dembo's Avatar
Going anywhere near petrol scares me enough; I think I'll pass on the blow torch idea.
Hopefully it's the nuts that are shagged (though I think the studs are screwed into the manifold so can probably be replaced). The nuts are stuck to the extent that turning anti-clockwise is going round and round and not doing anything. I've ordered a nut splitter (£6 off Amazon) so we'll see how that works.
First time I took mine apart I dropped two of the injectors down through the manifold. I wasn't expecting them to just fall out. Top tip: leave the electrical connectors attached.
Old Jul 18, 2011 | 09:12 AM
MB's Avatar
MB
Member
Those bolts do come out, I still have one sat down on the engine somewhere
Nut splitter and new nuts for you.
s2kNORcali
Feb 26, 2010 01:17 PM
guedo
Oct 29, 2008 10:39 AM
Nate4635
Aug 8, 2008 11:58 AM
Itchy Dick
Jun 12, 2008 03:43 PM
s2konroids
Jun 1, 2007 11:57 AM
