Engine torque damper
Old Aug 16, 2013 | 03:47 AM
D7PNY's Avatar
Originally Posted by jsh
Not in the turret ! In the bracket that bolts onto the turret that comes with the ETD.
Ah...I'm with you now! All makes sense now
If it's just drilling another hole in the bracket then that doesn't bother me too much.
Cheers,
Dave
Old Aug 16, 2013 | 04:03 AM
yorkies2k's Avatar
Mine was too long ! some people where taking the damper apart to modify the internal's?? Thus making it shorter .
I found it easier to drill a hole in the suspension turret bracket further back so that it would fit as it was .
I modified the internals but yes, was too long out of the box. That was back end of last year I bought mine
Old Aug 16, 2013 | 06:30 AM
curren1963's Avatar
I fitted an Ingalls Stiffy ETD straight from the box (distributors were Funky Power). Didn't think it made much difference though
Old Aug 16, 2013 | 06:35 AM
D7PNY's Avatar
Does it not stop the engine rocking under load?
Not worried about what they claim to do for gear changes and all that nonsense...just looking for something to stop my manifold from touching steering rack when under load.
Cheers,
Dave
Old Aug 16, 2013 | 08:52 AM
markforrester99's Avatar
Ingalls is by far the best design, you can see they have really thought about how they can mount it. You can adjust the stiffness, mines been great ive done 5 trackdays on it and its taken some abuse on the road and it still works fine
Old Aug 16, 2013 | 09:51 AM
Montag's Avatar
As Mark says, the Ingalls is a better design owing to its mounting. With the Tegiwa, you'll have to cut a hole in your heat shield (if you've still got it in place). Both ETDs perform the same job and there isn't really any difference in that respect; the only big difference is in the price!
Old Aug 17, 2013 | 07:30 AM
pballs's Avatar
fitted a stiffy, 10 minute job, no need to cut/shorten/adjust anything, just fits out of the box, it does make a difference to the engine rocking...
oh, and i had to fit one to stop the PLM manifold rubbing on the steering column.
Old Aug 17, 2013 | 08:38 AM
D7PNY's Avatar
Sounds like that's what I need to but then
Cheers,
Old Aug 17, 2013 | 10:09 AM
You need allen keys for assembly, best to have allen key sockets and you can use an extension to tighten the securing bolts for the brackets.
Old Aug 17, 2013 | 11:47 AM
D7PNY's Avatar
Cheers, got a set of Allen head sockets as nearly all the bolts on my old Westfield were Allen heads!
D7PNY
Dec 5, 2013 02:09 PM
gbduo
Apr 2, 2012 05:15 PM
dave.irl
Dec 30, 2011 02:42 AM
GaryB
Nov 1, 2011 04:57 AM
Tyraid2K
Jun 13, 2007 03:56 PM
