Exposed Map Sensor
Exposed Map Sensor
A little while ago, I took my car for its 54k Service.
A short while after the Service, the Check Engine Light came on; I diagnosed the fault with an ODB II reader (P0301 - Cylinder 1 Misfire) and have booked the car back in with the dealer to get it checked out.
In the meantime, I had a poke under the bonnet this evening to see if I could spot anything that may be obviously causing the problem and noticed the Sensor Map is exposed. Is it reasonable for me to assume this should be covered up ?
I don't usually spend much time under the bonnet (other than routine maintenance and cleaning), but I'm sure this isn't right ...
As always, any advice appreciated
