Headlight trouble – Driver’s side not working
Old 04-07-2011, 03:59 AM
James Rae's Avatar
Default Headlight trouble – Driver’s side not working
My offside headlight stopped working a while back, so I booked the car into my local Honda dealer (Darlington’s in Harlow) for investigation.
The garage found the headlight fuse blown, replaced the fuse and fitted a new bulb but still can’t get the headlight working. They say it could be the ignitor or control unit or both.
From a quick search on here I’m guessing it’s more likely the control unit (I’m assuming the control unit is also generally referred to as a ballast on S2KI).
Any advise would be greatly appreciated – I’m currently looking at getting a 2nd hand control unit fitted and hoping that solves it, any comments on this or other suggestions would be gratefully received!
Diagnostics wise, I’m not sure if this helps identify the issue but when the headlight first stopped working the blue ‘full beam’ warning light lit up on the dashboard at around half its normal brightness whenever I switched on the headlights. Since the garage have changed the bulb and fuse though, this no longer happens – I just get the normal ‘headlights on’ dashboard light.
Side lights and full beam are unaffected and work fine on both sides.
Old 04-07-2011, 08:41 AM
richmc's Avatar
Two lights on the car! try swapping bits over. Suprised Honda didn't try that.
Old 04-08-2011, 02:23 AM
James Rae's Avatar
They said no can do as the parts are different for each side - is this nonsense?
Old 04-08-2011, 04:15 AM
loftust's Avatar
Even if the ballasts are not permanently interchangeable, they have the same connector, so it is worthwhile for diagnostic purposes
Old 04-08-2011, 07:26 AM
Nick Graves's Avatar
It's a lot of fart-arseing about.
If there's buzz down to the Ballast, then it's the ballast.
Best not to check buzz out of the ballast, since it's 23Kv and you have to be careful with that.
Old 04-08-2011, 09:00 AM
richmc's Avatar
Not just nonsense but total boll**ks, as loftus said the connectors are the same. BTW Hi Loftus you've not been around for a while, been away playing boats?
And as Nick said loads of volts there (Honda wimps!)
Old 04-08-2011, 11:38 AM
loftust's Avatar
Yes, I have been away recently and have been playing around on picket boats
The method I suggested is a right faff, but is worth it to confirm the problem
1four7break
04-06-2015 12:38 AM
SilverS2kF22C1
03-12-2010 05:56 AM
s2kev
05-21-2006 01:22 PM
trick408
04-16-2006 06:47 PM
anishd
06-17-2004 07:55 PM
Quick Reply: Headlight trouble – Driver’s side not working
